SpotlightCreating a basic stage
Command
Workspace: Path
Create Stage
Design Suite: Entertainment > Event
Spotlight: Spotlight > Event
Many event rooms contain a stage for viewing presentations. Based on the Stage Deck and Stage Plug tools, a stage is automatically created according to specified parameters. The required number, size, and type of stage objects automatically fill the designated area. For more customizable options, see Inserting stage structures.
To create the stage area:
Create a closed 2D object (such as a rectangle, polyline, or polygon) to represent the stage. The dimensions of the object should match the dimensions of the stage to be created.
With the 2D object selected, select the command.
The Create Stage dialog box opens. Specify the stage properties and attributes. Some information from parameters can also be placed on the drawing using the Text Options.
Parameter
Description
Stage Height
Specifies the overall stage height
Standard Stage Deck Width / Depth
Specifies the dimensions of a rectangular stage
Structure
Select the type of stage construction; stage plug objects are shown as an example
Top Thickness
For Legs-Basic and Deck Only stages, sets the thickness of the deck
Trim Height
For Legs-Basic and Deck Only stages, sets the height of the trim around the stage
Leg Diameter
For Legs-Basic, sets the diameter of the leg supports
Leg Profile
For Legs-Basic, select a round, square, or octagonal shape for the legs
Leg Reference Spacing
For Legs-Basic, sets an approximate spacing value for the legs; the exact spacing is determined automatically by evenly dividing the length of the deck
Minimize Leg Count
When multiple stages fill an area, removes unnecessary legs from Legs-Basic structures that are supported by adjacent stages
Add Casters
For Legs-Basic, adds casters to the legs to create a rolling platform
Object Class
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class
Purpose /Set Cart ID/ Note
Enter information about the stage (does not affect the stage appearance)
Fill Color
Sets the fill color for the stage
Pen Color
Sets the pen color for the stage
3D Options
Specifies the appearance of applicable deck elements in 3D views. The 3D Options dialog box opens.
For each available portion of the stage, either select the color from the Color list, or select Custom Texture and then click the current custom texture to open the Resource Selector; double-click a resource to select it. The Object Info palette displays the color or texture selections in the relevant section.
The appearance of Simple stage decks is set from the Attributes palette.
If the area is rectangular, stage decks are inserted; otherwise, a combination of stage deck and/or stage plug objects are inserted.
Individual stage parameters can be edited in the Object Info palette; see Inserting a stage deck and Inserting a stage plug.
Creating the room for a basic event
Creating basic stage stairs
Creating a lectern
Creating a basic video screen
Creating seating sections
Creating basic event views
Concept: Resource libraries
